Problems with Script Triggers
I've been trying to use a script trigger attached to the last data entry field on a layout to jump to the next layout in a series and the script is behaving strangely and I thought I might ask the forum for some advice.
I have the following script attached to the (second) layout (that normally runs without any problems on layout enter) which sets some variables and then goes to the first field on the layout
Set Variable [ $$Current Measure; Value:If .....
Set Variable [ $$Measure Context; Value:If ( PatternCount.....
Set Variable [ $$Measure Timepoint; Value:Neuropsych Sessions::pfk_Administration Timepoint ]
Set Variable [ $$Measure Session; Value:Neuropsych Sessions::ppk_NP Session Number ]
Set Window Title [ Current Window; ......
Adjust Window [ Maximize ]
Refresh Window
Go to Next Field
However when I set the following script to run on LayoutKeystroke (attached to the last field on the first layout) the second layout loads fine, but then the active field jumps from the first field to the SECOND field on the layout...nothing I seem to do will change this behavior. I'm positive that this has something to do with the fact that I'm hitting the enter/tab/return key on the previous (first) layout once and its somehow being carried over to the next (second) layout as the second layout loads. If I change the settings for the first field (on the second layout) so that "go to next object" no longer works with return, then go back to the first layout and hit return to exit the last field the script works fine---I don't jump to the second field as I switch layouts---- (but i here the mac "bonk" noise that means a key was pressed that won't do anything).
If [ Let( keyCode = Code( Get ( TriggerKeystroke ) ); keyCode = 9 or //Tab Key keyCode = 10 or // Enter keyCode = 13 // Return)]
If [ not IsEmpty ( Get ( ActiveFieldContents ) ) ]
Go to Related Record [ From table: “Neuropsych Sessions”; Using layout: (Get ( LayoutNumber) + 1) ] [ Show only related records ]
Go to Next Field
End If
End If
any advice would be greatly appreciated
Exit Script[False] will cancel the tab.
Put that inside an If[] statement (or calc it inside the script result).
It works perfectly, you are a godsend!
thanks so much
