portal problem
Hi
I am a user of Filemaker Pro 10, and I have a problem:
I have a portal in a layout which has several rows, and each row has an id, and also a field called position.
Sometimes there are a few portal rows with same id , but different values in position field.
Now I want to have those rows of the portal which have a specific id (let's say 3) in another layout.
How can I write a script so that I can just have those portal rows with id=3 in portal row format in my new layout?
I will really appreciate any help.
Best,
Sepideh
You could make a script that sets the id of the row you click into a global variable, then goes to your other layout. E.g.:
Set Variable( $$selected_ID ; related::id )
Go to Layout( B )
On layout B, filter the portal by the global variable, with a calc like:
id = $$selected_ID
