Problem with Summary Field
Hello Guys,
I have a problem with setting the summary report. I attach a sample file which contains a report using summary field. The problem is I can't multiply a summary field's value to another field's value and get a correct result.
Any help would be appreciated in advance.
Kind regards
Product.fp7.zip
Try it this way, perhaps?
Product2.zip
Thanks a lot. It works perfectly for me.
But I still have this question "can we use a summary field in our calculation?"
Yes, you can - but is more complicated in this case. First, you must use the GetSummary() function for the sub-summary results. For this, the breakfield cannot be a related field; you must sort and sub-summarize by the "local" ProductID field. You also cannot total the results of the calculation, because it returns a result for every record.
as you said it is getting more complicate for me.
thanks a lot for your help
