Compatibility of script triggers made from FM 10 Advance to FM pro 9
Hey guys and gals..
I made some script trigger in FM 10 advance.. then tested it, but it doesnt work in FM pro 9..Is there a way i can make the script trigger function in fm pro 9?Thanks!
No way. Script triggers were introduced in FMP 10.
There are plugins that allow script triggers in earlier versions - but there is no "compatibility" between the two methods: if you use a plugin, you'll need to redo your triggers.
