!!! Still Email problems !!!!! PLS help me...
Try to describe problem better:
Using FM 5 for Windows.
Have a layout with fields.
NAME : "here is the data"
CODE : "here is the data"
STATUS : "here is the data"
When I push the button SEND MAIL", I activate the script containing SendMail routine.
The TO field is constant, and I have put in a predefined address. Same with subject.
BUT message is the problem. It should look like this at the receipient end:
TO: "predefined"
SUBJECT: "predefined"
MESSAGE:
NAME : "here should the data come from field"
CODE : "here should the data come from field"
STATUS : "here should the data come from field"
All this text (for MESSAGE) should appear in MESSAGE of mail.
How can I add SEVERAL data fields in the message area WITHOUT using any plugin :
Meaning a description of the field, and then the field itself?
Thx in advance,
Stigh
[This message has been edited by stigh (edited October 07, 2000).]
To create a message with the data from serveral fields you need to create a FileMaker field that is a composite of the fields. For example, if your field are:
Name (text)
Code (number)
Status (test)
Create a composite field:
Message (calculation, text) =
"NAME : " & Name & "
