February 22, 201214 yr Script that runs perfectly on client side from a remote computer, or from fmkr client installed on the server, gives me an error every time at the emailConnectIMAP script step. Being run on OS X Lion Server The error returned is "Login failed." There is no firewall The plugin is installed on the server The emailRegister step is returning properly I'm running the script with admin privileges There is no error being returned in the Server Logs
February 23, 201214 yr you may check your 360works logs in the server logs to see what error it is throwing out.
February 23, 201214 yr Author Thanks for your response. I had checked that already but forgot to put that in my post. Interestingly enough, no error at all.
