February 27, 201214 yr Hallo, I experience some problem with POST XML to URL plugin. I try to POST xml request to server, but there is some problem with characters - it shows in the message. The problem is only with Russian chars, no problem with English or numbers. It seems to be problem with charset, in the request it must be only UTF-8. The XML is the following: <?xml version="1.0" encoding="utf-8" ?> <package login="lik" password="XXXXXXXXXXX"> <message> <default sender="LIK"/> <msg recipient="+79161770129">test и тест</msg> </message> </package> The message i get from SMS server - "test ? ?" Please Help to solve the problem and sorry for my English)
February 27, 201214 yr Hello Andrey, If the service has documentation you could check the encoding of the response and/or the request?
February 28, 201214 yr Author The encoding must be only in UTF-8 for requests and response is also in UTF-8. But it seems like POST XML to URL plugin posts request in different encoding... Can you please tell me how to send the request in UTF-8 (now it seems to be in UTF-16)?
February 28, 201214 yr Author And here is the code of plug-in: // Send data URL url = new URL(url); HttpURLConnection conn = url.openConnection(); if( soapaction != null ) conn.setRequestProperty( "SOAPAction", soapaction ); conn.setRequestProperty("Accept-Charset", "utf-8"); conn.setRequestProperty( "content-type", "text/xml; charset=utf-8"); conn.setDoOutput(true); OutputStreamWriter wr = new OutputStreamWriter(conn.getOutputStream()); wr.write(xml); wr.close(); // Get the response String response; InputStream responseStream; try { responseStream = conn.getInputStream(); success = 1; } catch( IOException e ) { success = 0; if( conn.getResponseCode() == 500 ) { responseStream = conn.getErrorStream(); } else throw e; } response = responseStream.getText("utf-8"); responseStream.close(); return response; And XML i try to send: <?xml version="1.0" encoding="utf-8" ?> <package login="lik" password="XXXXXXXXXXX"> <message> <default sender="LIK"/> <msg recipient="+79161770129">Some text in Russian. Its where the problem is!</msg> </message> </package> Thank you!
February 28, 201214 yr The module is really simply a proof of concept. Changing the default encoding scheme is a little outside the scope of support. However, I've dug into this a bit an it looks like this forum post might be useful. Basically, it looks like you can modify the module to change the string coming from FileMaker to UTF-8 by adding something like the following: xml = new String( xml.getBytes("UTF-8"), "UTF-8" ); You may also need to change the encoding on the response as well. If you'd like us to look into doing this for you we do offer custom development and I can provide a quote for that directly if you want to pursue that option.
February 28, 201214 yr Can you provide the URL you are using for the service? I can try to test it locally if you can.
February 28, 201214 yr I tried the URL you included but don't seem to be able to get it to work. Is it possible for you to email me the ScriptMaster file with the input variable (URL) included?
February 28, 201214 yr Author Oh, sorry, I forgot that they have IP filter...only requests from my IP will work. You can provide me your IP, or i can follow your instructions to test it and give you result...?
February 28, 201214 yr You can try adding the line above to the module. I'm not an encoding expert but I believe this will create a new string with the correct encoding. Again, you may have to do something similar thing with the response.
February 28, 201214 yr Author Thank you, it helped!!!) For the others: the full code is // Send data URL url = new URL(url); HttpURLConnection conn = url.openConnection(); if( soapaction != null ) conn.setRequestProperty( "SOAPAction", soapaction ); conn.setRequestProperty("Accept-Charset", "utf-8"); conn.setRequestProperty( "content-type", "text/xml; charset=utf-8"); conn.setDoOutput(true); OutputStreamWriter wr = new OutputStreamWriter(conn.getOutputStream()); text = new String( text.getBytes("UTF-8")); wr.write(xml+text+xml2); wr.close(); // Get the response String response; InputStream responseStream; try { responseStream = conn.getInputStream(); success = 1; } catch( IOException e ) { success = 0; if( conn.getResponseCode() == 500 ) { responseStream = conn.getErrorStream(); } else throw e; } response = responseStream.getText("utf-8"); responseStream.close(); return response; and there are 4 Variables: URL XML TEXT XML2 SOAPACTION THANK YOU VERY-VERY MUCH FOR HELP!!!
