Finding problem
Hi Lee,
Here is my file please take a look to see what is wrong.
Cheers
Stock Journal.fmp12.zip
I see there was some interest in my post, some downloads but no replies, anybody has some ideas to help me?
Cheers.
It might help if you describe your problem - I can't "see" because it's a FM 12 file.
Your profile states you are using FM 11?
Sorry efen,
The profile is updated now :)
How can I send to you a FM 11 version of my file?
Attach it to this thread
One of the problems is:
I have 6 tables and 6 Layouts, each one has one Total field selected as Summary from many calculations.
Each table has a ID serial number that I used to make the relationship between all tables (don't know if it is correct).
In the Main Layout I need the total of the field Summary of all tables.
I don't know how to list and how to SUM the fields Summary from 4 of this tables.
:hmm:
I did a quick mockup of the file for those that are not using 12 yet
Stock Journal.fp7.zip
