SMTP problems using Exchahange 2010
Using FileMaker 11 Sever, Advanced, Client and IWP
smtp script command when options are added works correctly from
IWP but not from the FileMaker client. Are there settings in Exchange that are blocking FileMaker Pro
to send mail using the smtp option. This problem is at a client and I dont get the privledge of looking
into exchange.
Any Ideas
Answer, In case you are interested. Problem drilled down to Exchange is only allowing FileMaker to
send tto receipients that are within their own domain name. Every other domain gets blocked.
So it is a relay problem on the Exchange server.
  • 3 weeks later...
Are you using authentication on the SMTP Options screen? I had the same issue and that fixed it for me.
I set it to Plain Password with my user name and password and it then worked for non-internal emails as well as internal.
