Goto Script help
I've got a work order database that shows a portal at the bottom. The portal shows shipper number, how it was shipped and the invoice number that shows the bill. I've tried to make a button on the number itself that is in the portal. Once the button is selected I would like it to goto that invoice number. I've tried goto related field, open, etc... I'm guessing because it's in a portal I can not make it work with out a calculation. Does anyone have a suggestion on how to make it work.
Please see the attached picture for more info.
See the attached.
post-100295-0-76564000-1339786629_thumb.
Hi -
What are the tables involved, and how are they related?
If you have a button in a portal, and use the Go to Related Record script step, and specify the correct relationship and appropriate layout, the result will be: you end up on the related record.
Why does your screen shot point to the Go to Work Order button at the upper right? That doesn't seem to match what you described in your post. You want to click the portal row and then click the button? As opposed to just clicking the invoice number in the portal?
