Problem with Attachments and Variables
What I have been doing is, first I set a loop so that it grabs 1 field, the same field, which is the raw data URL from the container, and sets it up in the variable. This is the calculation:
Set Variable [$List ; List ( $List ; "EmailAttachFile( "&"\""&Documents::_c_RawData URL&"\""&" ) and" )]
It appears to get the data correctly, because I have it set a random field just to make sure. So I setRandomField $List, and it displays what I have gathered from the records:
EmailAttachFile( "http://url1" ) and
EmailAttachFile( "http://url2" ) and
EmailAttachFile( "http://url3" ) and
When I run the following script, it nothing happens however (I took out the email information for privacy):
EmailSetBody( "This is the body of the email" ; "plain" ) and
$List
EmailSend and
EmailDisconnect
BUT, when I run the following script, it works perfectly:
EmailSend and
EmailDisconnect
Any thoughts on why this is happening?
If you are assigning the variable $List to the result of the EmailAttachFile function calls the value in that variable will be 1 (provided there are no errors). If you are doing this before calling EmailConnect or EmailCreate it will not have any message to attach the files to and should return an error instead. In either case, the result of calling the EmailAttachFile functions is not the same thing as calling them. It appears this is why you are experiencing the difference in behavior.
Here is my full code, obviously with the real email information hidden for privacy purposes. This is the whole step, and is a calculation for $result variable:
EmailConnectSMTP(
"smtp.gmail.com:465" ;
"[email protected]" ;
"hidden" ;
"ssl=1") and
EmailCreate ( "[email protected]" ; "[email protected]" ; "Hidden" ) and
$List
EmailSend and
EmailDisconnect
I think I understand what you mean by this, meaning that it's bringing it in as text rather than the function. Do you know how I can solve this?
You can't really "solve" this as the function will be executed wherever it is being called. In your case, that looks to be in after the EmailSetBody call. You should still be able to create a script that has logic to accomplish what you need.
