CreateFolder Module - using variable in pathToCreate?
I want the folder to be created to be names as today's date in a Month-Day-Year format. So 8-9-2012. I added calendar code to it:
//Really simple version:
//return new File(path).mkdirs();
//Version with decent error reporting:
File dir = new File(pathToCreate);
Calendar cal = new GregorianCalendar();
// Get the components of the date
int year = cal.get(Calendar.YEAR);
int month = cal.get(Calendar.MONTH);
int day = cal.get(Calendar.DAY_OF_MONTH);
if( dir.exists() ) return false;
if( dir.mkdirs() ) { //Success!
return true;
} else { //Figure out why it failed
File realParent = dir;
while( realParent != null && ! realParent.exists() ) {
realParent = realParent.getParentFile();
if( realParent != null && !realParent.canWrite() ) {
throw new FileNotFoundException("Directory " + dir.getAbsolutePath() + " could not be created because the parent directory " + realParent.getAbsolutePath() + " is not writeable" );
} else {
throw new FileNotFoundException("Directory + " + dir.getAbsolutePath() + " could not be created because of an unknown error." );
but how do I get variables to work in the pathToCreate? I tried /Users/erickornmeyer/Desktop/DBPrice Updates/Pricing/Vendor Cost Updates/$month-$day-$year but it didn't do anything. Any help would be appreciated!
You are making the file object before the calendar stuff and then not doing anything with it
This might get you nearer
SEP = System.getProperty('file.separator')
pathToCreate = pathToCreate + SEP + month + '-' + day + '-' + year
// will give e.g. path/child/01-31-2012
return true
} //end while
throw new FileNotFoundException('Directory ' + dir.getAbsolutePath() + ' could not be created because the parent directory ' + realParent.getAbsolutePath() + ' is not writeable' )
} else {
throw new FileNotFoundException('Directory + ' + dir.getAbsolutePath() + ' could not be created because of an unknown error.' )
} //end if
} //end if
although you could do
end = new Date().format ('mm-dd-yyyy')
pathToCreate = pathToCreate + SEP + end
Worked great except the output was 31-14-2012 for today. Not sure where it is getting that month value
Changed it to MM and it works now, thanks!
