Help with Style sheet with repeating tags
I am hoping someone can guide me with my stylesheet for the attached xml.
I want the "Comp" (which are real estate comparable sales) to import into separate records.
The import routine recognizes the mapping just fine, and I get no errors on import... except no data imports.
The second Test.xml is a corrected version.
Test.xml
Test.xsl.txt
Test.xml
What does that mean? Which version do you want us to refer to?
Use the second Test.xml as an example. I dont know how to delete the first one
Change this:
<xsl:for-each select="*/comp">
to this:
<xsl:for-each select="//comp">
or even better:
<xsl:for-each select="response/properties/comparables/comp">
BTW, you can simplify this (and the other two):
<xsl:value-of select="./address/street"/>
to:
<xsl:value-of select="address/street"/>
Great. I will give that a shot
  • Awesome. Did the trick (wish I knew the foundations). Thanks
Comment.... can you tell me how to grab the "score" which is an attribute of comp tag?
Try:
<xsl:value-of select="@score"/>
Recommended "basic training":
http://www.w3schools.com/xpath/default.asp
Thanks very much. That helps a lot
