Help - Can I get data from my runtime solution?
I just deleted 2000 records by mistake from my original .fp7 file and I don't have a backup. I found a runtime solution I had made of the database but I think it doesn't have admin privelages, and I don't have the option to export data. How would I open it with admin if it did have admin access as in .fp7, I usually hold down shift when opening the file?
Ok, is there any conceivable way to get data from the .USR file or any other file in the runtime folder.... or am I up the creek without a paddle?
Thanks so much,
A .USR file is exactly the same as a .fp7 file - with only a flag turned on. You can open it using the FMP application - but the accounts and privileges set in the file will be enforced equally by both the runtime engine and by the FMP app.
You just saved my behind. I got in and I got what I needed. Thanks so much, I really appreciate your advice.
Have a lovely day.
