Ampersand and Commas causing problems with LeftWords, etc
I have a Calculation field containing text such as "Cats & Dogs" and "One, Two, Three"
I need to replace all occurrences of 'space' in every occurrence in this field with a string (' ' as it happens) but when I use functions such as LeftWords or PatternCount in doing this, the '&' is ignored, and the 'commas' in One, Two, Three get stripped out.
I presume that FMPro is treating anything non-alphanumeric as 'whitespace'.
What is the most elegant solution to this problem?
Using FMPro 8.5, and not planning to upgrade in the very near future...
Why not use the Substitute() function?
That is an incorrect assumption. Some characters are word delimiters, some are not. And some characters are word delimiters only under certain circumstances.
Thanks! I took a wrong turn by choosing to use PatternCount( ) rather than Susbtitute( ).
It hadn't seemed obvious to me that Susbtitute( ) worked on ALL occurrences, and it happily handles & and ,
Thanks for your help. My problem now seems to be solved. :)
