Problem under Tiger and G3
Hello,
I had a problem after updating to the last version of SM under Tiger 10.4.11. I use SM to get from Amazon datas about a book after entering the ean or isbn. It worked fine by the past and works well on my iMac under Montain Lion... I installed an old version of Tiger on a separate disk and booted from it. I installed my app : after entering isbn or ean nothing happened.... After downgrading the pi to 4_02 everything worked fine.
Another problem is always present for me : the same app running on a machine with G3 processor can't acquire datas from Amazon through the same script  in SM. Questions :
  1. Is ScriptMaster incompatible with G3 ?
  2. If not where can we get old versions of the SM plugin ?
Thanks a lot for your help
Noël
I maybe said an enormous stupidity so that no answer cannot help me!
Or then I am still indistinct?
Thank you...
Noël
If I remember correctly, Tiger (10.4) is incompatible with G3. It could be made work with some tweaks but officially 10.3 was the last OS for G3.
Thanks for your answer... but I did not know that limitation. And don't understand how it can explains that SM script doesn't run...
Noël
