writing a report letter using related records' values
Hello, I am currently developing a database using fm pro 13 and i need a calculation field that writes a paragraph using related record values
In my case: I have a table called event related to a table called transfusion in a one:many relationship.
I have a portal on the event layout that has the field
transfusion::Blood product, transfusion::Dose, etc
The blood product can be RBCs, platelets, albumin and/or IVIG
So each record in transfusion will have a blood product and other information.
I have a layout that prints a form for the medical daycare unit. I want this form to display the information from transfusion in a coherent fashion.
For example, if transfusion::Blood product = "RBC" then "Please give the following blood product: RBC" and dose
and if another record related to the event contains platelets then the platelet info will show as well.
I was able to perform the function using a checkbox or a repeating field but I find using a related table makes things look much better and organized.
Can anyone help me with this. If you need more info please let me know
thank you
One approach:
base your report on a Transfusions list layout; this would also allow you to easily group and summarize, and you could use the same layout to report by date range, Event record(s) or other criteria.
Another one:
pull in a list into the Events table.
• create a calculation field in the Transfusion table that calculates the complete string you want to have displayed per transfusion record, based on the values for fields like bloodProduct etc.
• create your list from the Events context by using List() with your calculated field, e.g. List ( Transfusions::cCompleteTransfusionMessage ).
Note for this second approach that if you only need this list when reporting, you wouldn't necessarily have to create a dedicated calculation field in Events; pull in the list in the course of your report script and place it into a global field or a merge object/variable (or whatever fits the way you've set up your report).
One approach:
Another one:
This is perfect!! thank you very much!
