Finding Null values in a field - HELP
Howdy All:
I have a quandry i would like help on:
I have a database i am rebuilding ( About 245 layouts with more than 900 fields) - I know!
I am trying to clean up the data by process of searching and eliminating certain records. I have criteria for about 6 fields to search, but the last three fields are looking for NULL data:
IE:
Doc Date (omit) Null
Billing Date (omit) Null
Results (omit) Null
I have the add request thing down pretty good, but how do I specify to FileMaker that I want to search for this NULL data in these fields?
If this is a very simple question, please feel free to e-mail me a Cluepoun with your answer.
Thanks again!
Nitewolf
Just enter an equal sign "=" into the field. This matches a blank field (leave out the quotes).
-bd
bd:
Thanks for that. It worked! I am going to post another Q to the list, maybe you can take a look.
Thanks in advance!
Nw
