script to find records using minimum & maximum values
sorry, I am a novice in scripting...
I have a button which has to invoke a procedure to fill in two fields with a minimum and maximum thickness value ;
this should return a list of all records matching the values between those two; just as you can easily do manually in the find menu bar inserting the proper operators
Attention: the minimum needs to calculate with ≥ , the maximum with <
example:
product 1 : min thickness 2 mm (≥), max thickness 4 mm (<)
product 2 : min thickness 3 mm, max thickness 6 mm
product 3 : min thickness 6 mm, max thickness 8 mm
search: client wants a product offer between 2 and 6 mm > should return product 1 & 2, not product 3
table is called "steels"; layout is called "search"; fields min values: "minTh"; field max values "maxTh"
thanks for giving me a clue to get this calculated in a script ?
somehow scripting does not allow to create numbers ?
Set Field[ (steels::minTh)  ????? ]
Set Field[ (steels::maxTh)  ????? ]
Your syntax is wrong for the Set Field command:
Set Field[steels::minTh;"≥ 2"]
Set Field[steels::maxTh; "≤6"]
yes, I know, but how can I catch the variable number that the user has put in in place of "2" and "6" ?
Like this (attached example).  You could also use a Show Custom Dialog[] instead of presenting the global fields if you wished.
Oh!  And welcome to FMForums!  :-)
Added:  What I wanted to explain is that when wanting to find a range of values, use min...max.
Thickness.fmp12.zip
great, works with a bit of mending (max en min fields in different fields), now adding extra filters,
thx a lot ! greetings from Belgium !
