January 15, 201511 yr I have a database called CABINET DATA that I use to manage math for my cabinet shop. The database contains a lot of fields that are necessary to calculate the math but far more information than we want to have on the shop floor. I want to be able to extract the values from just a few of the fields and have them show up on a separate table called CUTLIST. If, for example, a cabinet contains 4 shelves I want each shelf to show up on the list individually rather than have a separate field that indicates quantity. By having each shelf show up on a separate line it is easier to see how many shelves have been cut and which ones remain to be cut. I would like to populate CUTLIST with values from the current record on CABINET DATA. To minimize the amount of code needed I would like to do this with a SET FIELD script. The script I have creates a new record on the CUTLIST table but instead of posting values from the current record always posts the data from the very first record. Is it possible to script SET FIELD to show values from current record rather than first record? BOXBUILD Copy.fmp12.zip
January 15, 201511 yr Upon examining your database, the first thing to notice is that you should define your relationship(s) correctly; at the moment it is using two global fields as match fields! While Cabinet does have a serial field (but it's not being used in the relationship), Cutlist doesn't have any serial fields: neither a primary nor a foreign key field. Your script is performing a search – what for? Shouldn't there only be a single relevant Cabinet record? Or what does a Cabinet Input record represent? – using Copy (without a field, which copies all fields of the record) and Paste; that can't work (and doesn't). Since there is no error trapping, you probably didn't notice this … Then, you're going to the other table, creating a new record, but don't do anything to make it a related record (and without a foreign key field, how could you …?) What then is the result calculation of Set Field [] supposed to return? Also, since Cutlist is supposed to be either a child table, or a one-to-one (or that's what I think; as noted above, I don't really understand your data model), once you've set the foreign key in the new record correctly, there is only one related Cabinet record, so you will always refer to the correct one. Don't use copy & paste; use Set Variable [] / Set Field []. Finally, if shelves are an entity in their own right, you should create a Shelves table as a child table to Cabinet; there you can define each shelf individually, gives it its own status etc., remove all fields that are necessary for shelf definition from Cabinet (and create any number of shelves without having to create new sets of fields in Cabinet …)
January 15, 201511 yr Author EOS, Thanks a lot. I am a pretty good cabinet maker but, as you have pointed out, no so much of a developer. I was, however, able to take your clues and make it happen. Thanks a bunch!!
