problem with iText on OS X 10.10
Scriptmaster 4.42  running as a a server plugin with FMS 14.02
If I load jar files locally the following code works, if I run it as a PSOS script - with the jars loaded into the JVM, it appears to not properly load the resources, so I get the error message underneath, which point to the the fact that A: the .lng is not loading so it can't find the error message and that the helvetica.afm is also not loading which causes the error
import com.itextpdf.text.pdf.BaseFont
try{
bf = BaseFont.createFont()
return bf
} catch (e) {
return e
return true
 error is
com.itextpdf.text.DocumentException: No message found for 1.not.found.as.resource
see following as it appears to be a JVM issue.
http://stackoverflow.com/questions/31357638/helvetica-base-font-returning-an-error/31358097?noredirect=1#comment50698373_31358097
Edited by john renfrew
Its definitely a problem with 4.42. I just went back to 4.4 and all is working again.
john
  • 3 weeks later...
Now that DevCon is over and done, is there a chance you could take a look this issue please....
  • 1 month later...
Ryan
as you seem to be answering. Any ideas on this one?
