DataTables Deep Dive - Replacing Portals - Part 2
This is Part 2 of a series about using the DataTables JavaScript library in order to simply pull data you wish to display and doing so within a Web Viewer.
While standard FileMaker Portals present one of the easiest methods for showing related data, it's now a viable option to simply use a Web Viewer to present data to the user. With the bi-directional support of JavaScript within FileMaker 19 and higher we can take advantage of what JavaScript does best - being fast!
In this video we focus specifically on the initialization and interaction between a Web Viewer using DataTables and how you can add buttons and features which make using DataTables a joy within FileMaker.
View the full article
