How to set a script to find by first letter?
I currently have the following script.
If [status (CurrentMode) = 1]
Perform Script [beep beep not in find mode message
[sub-Scripts]
Exit Script
End If
Have it search against just the first letter of the word, using the 'Left' function. Compare 'S' to Left(Fieldname, 1)
  • 1 year later...
I don't understand the reply. I'd like to know what you mean be Compare 'S' to Left(Fieldname,1). Is this in a command line? Not it the find field.
Thanks in advance!!
Hi Jim,
You can do this in a couple of ways.
One way is by using the NewField2, calculation field described below, and just do your find in it, or create both NewField1 and NewField2, and streamline it a bit.
NewField1 Global, Text
NewField2 Calculation, Text Result =
Left(NameLast,1)
Substitute "NameLast" with the name of your field for Last Name in the calculation above.
With these two fields, you can set up a script that will perform a find on whatever Initial you type into NewField1 in NewField2.
Or,
Use the two fields in a Relationship (NewField1 on the left and NewField2 on the Right) than use a portal utilizing this relationship. I would put the full name fields in the portal, and then by typing a letter in the global, the portal will reflect all records with that letter as the first initial in the portal.
HTH
