Deploying a solution with 500+ base tables
Will 360Deploy handle a Filemaker solutions that has more than 500 base tables (File size: 3.63Gb without graphic) ?
I have no problem of deploying the original demo file. Since the documentation 360Deploy Roadmap indicates that "You can also try 360Deploy out with your own solution, just be sure to rename your database file '360Deploy demo solution.", I tried, but failed.  Filemaker Pro Advance 16 always hanged at Step 8: Copy Script steps into '360Deploy Import Worker". See attached.  Any idea?
Hi dickiechung,
There isn't a hard limit for the size of the database. It may be that FileMaker didn't actually hang but rather was still processing that step due to the amount of tables that you have. How long did you let it sit before force quitting FMPro?
I force quit after 2 hours.
