Help with using tables from another database
I have 2 databases, each created with filemaker pro 16. They are both mounted on filemaker server 16.
So it's database A and database B.
In database A I added 3 tables from database B. I made a layout with some portals in database A that show information of database B.
Whenever I try to access this layout in database A, I get the login screen asking for my credentials of database B, Is there a way to tell filemaker just to use the admin account and always show the tables from database B with all permissions? (instead of always having to do the login)
If I don't put the credentials of an account with permissions to see this data, then the portal will show a message saying " < File missing >""
Would really appreciate your help!
Hi muskee,
Please don't use generic names for your Files, Tables, Field, Relationships, etc.., it adds confusion when trying to understand your question..
Hi muskee
You need to add accounts to Database B with exactly the same username and password as you have in Database A. That way, FileMaker will try to open Database B with whatever name/password was used to open Database A and show the data without asking for login.
If there is not a matching account in database B, then you will be asked for login credentials.
There is no way to tell FileMaker to use a specific name/password when opening a file that is referenced in 'Manage -> External Data Sources', you have to do what I describe above.
41 minutes ago, rwoods said:
Hi muskee
Thanks, solved!
