Is there a way to preserve String formatting in a script variable?
I have a script that builds an object that gets pasted into another application.
Over the years this objet has grown in complexity to the point where its a few hundred lines.    The problem I have is each time we update the object data I have to break it down line by line in filemaker with forced carriage returns and quotes inorder to preserve the formatting.
Eg:
{ objType {
  ActionName{
    action-item-1: test
    action-item-2: test2
becomes
{ objType {ActionName{action-item-1: testaction-item-2: test2}}}
as soon as the script is run.  Formatting seems to be preserved in the script itself but not upon variable assignment.
Any ideas how I could get this done?
Edited by NickFaraday
Could you provide a way (preferably a simple way) to reproduce this problem? I was not able to understand from your description what exactly do you start with and what do you do at the point where the carriage returns are lost.
BTW, the text you show looks very much like JSON - but it is not a valid JSON. With valid JSON the carriage returns (which are not essential) can be restored using the JSONFormatElements() function. But that's not an answer to why they are lost in the first place.
That may just be a Line ending problem.
e.g. substitute($text; Char(13); Char(10))
e.g. FileMaker needs Char(13), but other apps may prefer Char(10).
And JSON usually escapes returns with \r in the text.
Edited by MonkeybreadSoftware
