March 31, 200323 yr Hello, I was wondering if someone can help with me. I have database which list Business Referral. i create a portal where people can put first name, last name of referrals which is a link to another database call Referrals. i want the data entry to happen Business Referral and be display at Referral database. I dont know if my relationship is not working, i am doing the relation base on Company Id for the Business Referral database and Referral_id for Referrals Thanks, SolarPunk
March 31, 200323 yr First -- what are you saying??? When you enter info in a portal, it's actually being entered in the related file only. You need a portal to see it in the main file. In your case, if I understand at all, the Referral_ID in the related file will show the same data as the related Company_ID field in the main file. Other than that, I have no clue.
March 31, 200323 yr Hi, Not very clear....Just in case you were trying to create related records from referral to business referral. Set your relationship to "Allow creation of related records".
April 1, 200323 yr Author Thanks, Well, what i am trying to do is have portal in the main database which will the parent with a portal where the data will be enter and than display at the child, this are two seperate databases. Yes, this are related records. Thanks all, i need to read more about portal and relationship. Thanks, SolarPunk
April 1, 200323 yr Take a look at what you wrote, and grade it as an English teacher would. I assume that English is not your primary language, but you're not making sense.
April 1, 200323 yr Author Danja, yeah, english is not my primary languange. i got it to work. thanks all for the help.
