CDML Portal - Adding Portal Row Problem
Hello.
I have been trying unsuccessfully to add a row to my portal.
Here is my code:
<HTML>
<HEAD>
<TITLE>Register</TITLE>
<LINK REL=stylesheet HREF="http://myserver:591/OnlineReg/online.css" TYPE="text/css">
</HEAD>
<FORM ACTION="FMPro" METHOD="post">
<INPUT TYPE="hidden" NAME="-DB" VALUE="CE_Events">
<INPUT TYPE="hidden" NAME="-lay" VALUE="Online">
<INPUT TYPE="hidden" NAME="-Format" VALUE="personal_info.htm">
<INPUT TYPE="hidden" NAME="-Error" VALUE="p_error.htm">
<INPUT TYPE="hidden" NAME="-Token.3" VALUE="">
<INPUT TYPE="hidden" NAME="-Token.4" VALUE="">
<BODY CLASS="first">
<P>
<TABLE>
<TR>
<TD>Enter Personal ID:<INPUT TYPE="text" NAME="CE_Registrations::Personal_ID.0" VALUE="" SIZE=10></TD>
<TD>Enter Password:<INPUT TYPE="text" NAME="CE_Registrations::Personal_OP.0" VALUE="" SIZE=10></TD>
</TR>
</TABLE>
<BR>
<BR>
<FORM METHOD="LINK" ACTION="personal_info.htm">
<INPUT TYPE="submit" NAME="-Add" Value="Complete Registration">
</FORM>
</FORM>
</BODY>
</HTML>
Can any tell me what I'm doing wrong.......
Thanks! Donna
Donna,
"-add" does not exist. You would need to use either "-edit" or "-new" with
to create a new Portal row.
All the best.
Garry
I've just noticed that you have a nested Form:
</FORM>
This will not work. Just use the "Submit" with a "-edit" or "-new".
All the best.
Garry
Thanks Garry! As usual, something I just overlooked. I have reworked this now but it still is not working.
Perhaps my problem is that I'm trying to pass a token into a portal.
Here's my revised code:
<HTML>
<HEAD>
<LINK REL=stylesheet HREF="http://209.174.169.66:591/OnlineReg/online.css" TYPE="text/css">
</HEAD>
<INPUT TYPE="hidden" NAME="-DB" VALUE="CE_Registrations">
<INPUT TYPE="hidden" NAME="-lay" VALUE="Online_R">
<INPUT TYPE="hidden" NAME="-Format" VALUE="thank_you.htm">
<INPUT TYPE="hidden" NAME="-Token.3" VALUE="2003-TR24">
<INPUT TYPE="hidden" NAME="-Token.4" VALUE="OCLC/ILL: The New Web Interface">
<INPUT TYPE="hidden" NAME="-Token.5" VALUE="6057">
<INPUT TYPE="hidden" NAME="-Token.6" VALUE="XYZ123">
<P>
<TABLE>
<TR>
<TD>Personal ID: <INPUT TYPE="text" NAME="CE_Registrations::Personal_ID.0" VALUE="6057" SIZE=10></TD>
</TR>
<TR>
<TD>Password: <INPUT TYPE="text" NAME="CE_Registrations::Personal_OP.0" VALUE="XYZ123" SIZE=10></TD>
</TR>
<TR>
<TD>Event ID: <INPUT TYPE="text" NAME="CE_Registrations::Event_ID.0" VALUE="2003-TR24" SIZE=10></TD>
</TR>
<TR>
<TD>Event Name: <INPUT TYPE="text" NAME="CE_Registrations::Event_Name" VALUE="OCLC/ILL: The New Web Interface" SIZE=45></TD>
</TR>
</TABLE>
<BR>
<BR>
<FORM METHOD="LINK" ACTION="thank_you.htm">
<INPUT TYPE="submit" NAME="-New" Value="Complete Registration">
</FORM>
</FORM>
</BODY>
</HTML>
Any suggestions?
Thanks! Donna
To start with, you cannot have nested Forms! E.G.:
<BR>
</FORM>
</FORM>
</BODY>
Make it look like this:
<BR>
</FORM>
</BODY>
It seems to me that you are trying to add a new record to the file "CE_Registrations". However, the Portal has the same name which suggests that the Portal exists in another file, not "CE_Registrations".
Try this:
<HTML>
<HEAD>
</HEAD>
<P>
<TABLE>
  <TR>
                <TD>Personal ID:  <INPUT TYPE="text" NAME="Personal_ID" VALUE="6057" SIZE=10></TD>
 </TR>
        <TR>
                <TD>Password:  <INPUT TYPE="text" NAME="Personal_OP" VALUE="XYZ123" SIZE=10></TD>
  </TR>
        <TR>
                <TD>Event ID:  <INPUT TYPE="text" NAME="Event_ID" VALUE="2003-TR24" SIZE=10></TD>
 </TR>
        <TR>
                <TD>Event Name: <INPUT TYPE="text" NAME="Event_Name" VALUE="OCLC/ILL: The New Web Interface" SIZE=45></TD>
      </TR>
</TABLE>
<BR>
<BR>
</FORM>
</BODY>
</HTML>
Hope this helps.
Garry
