Newbie Needs Help With Simple Percentage
Hi All,
First time poster in desperate need of help.
I have a simple DB tracking actors at a talent agency. Each actor is assigned a Division via a value list: infants, kids, young adults, seniors. Each actor also has an Agent Status of a simple yes, no.
How do I get a running percentage of each Division's Agent Status? 50 kids total, 20 have agents = 40%.
I've gotten it to work, but only via a trailing grand summary on a dedicated layout for each Division. How do I get the percentage fields for each division to display correctly and update automatically and globally at the top of my main layout?
I know this is a lot to ask from a new member but any help would be greatly appreciated.
You need to set up some self-join relationships, one for each Division. Create 4 calculated fields whose formulae are simply the constant values:
cConstInfants = "Infants"
cConstKids = "Kids"
cConstYoungAdults = "Young Adults"
cConstSeniors = "Seniors"
Then create 4 relationships:
sjInfants: cConstInfants matches Division
sjKids: cConstKids matches Division
sjYoungAdults: cConstYoungAdults matches Division
sjSeniors: cConstSeniors matches Division
Now create 4 unstored calculations:
cAvrgInfants = Sum(sjInfants ::Agent Status)/Count(sjInfants ::Division)*100
cAvrgKids = Sum(sjKids::Agent Status)/Count(sjKids::Division)*100
cAvrgYoundAdults = Sum(sjYoungAdults::Agent Status)/Count(sjYoungAdults::Division)*100
cAvrgSeniors = Sum(sjSeniors::Agent Status)/Count(sjSeniors::Division)*100
These calculated fields will give you your percentages.
Hi Bob,
Hmm..
cAvrgInfants = Average(sjInfants ::Agent Status)*100
cAvrgKids = Average(sjKids::Agent Status)*100
cAvrgYoundAdults = Average(sjYoungAdults::Agent Status)*100
cAvrgSeniors = Average(sjSeniors::Agent Status)*100
with AgentStatus = is notEmpty(AgentField)
Wouldn't that work too...
Hi Bob and Ugo,
Thanks so much for your input! I'm trying these out now and hopefully I wont screw it up.
Am I correct in assuming that no grand summary part is required for this to work as you describe?
Stymied already!
When I try to create the first calculation field and use ConstYoungAdults = "Young Adults" I get a "This Field Cannot Be Found" error. Do I need to "point" this calculation at my Division field?
Thanks again in advance.
The Professor said:
Stymied already!
ConstYoungAdults is a field_name
"Young Adults" should be entered in the box qith quotes, and obviously must match one of your Division Name.
As for your previous question, no you don't need a Grand Summary for this to work. It's based on relationship while Summaries are based on the founds...
Worked like a charm!
Bob and Ugo, thank you so much for taking the time for a newbie.
