Please help me with a parsing question
I have a list on a floppy that I want to import into FileMaker 6.0 but the line information is separated by a space like;
Gary Stemper 12551 Wiffer Way Conroy, MI 66321 800/555-1212
So when I try to import it I get;
Gary Stemper 12551 Wiffer Way Conroy, in one field and
MI 66321 800/555-1212 in another field
Is there any way that I can get first name, last name, address etc. into each of the proper FMP fields?
Carl
Yes, there is a way, but it can take a long time. I recently had to do this. I used "grep" in a text editor. Grep is more or less cross-platform. I'm on a Mac, so I used BBEdit. There are editors for Windows, but I haven't used them; EditPad Pro has been recommended.
Basically you have to be able to recognize patterns of text, distinguishing between numbers and text.
It takes several steps to end up with the desired result. Yours is not too bad of a case however, 'cause there's so few "fields."
Example, Step 1:
Find: ^([a-z|A-Z]+| )+
(means: find words at the beginning with letters, no numbers)
Replace: &t
(means: replace with itself and a tab)
Step 2:
d+ (w| )+,
(find address, including comma, which hopefully only occurs here)
Replace: &t
Step 3:
[^t]ddddd
(find zip code, but not address#'s, which now have a tab in front)
Replace: &t&
(tab in front and back)
It's now done, but there's a little cleaning, to remove the the extra comma. You could also split off the area code.
Text editors can run these operations in a large file in a matter of seconds. You could probably do this with FileMaker calculations also, but it would be more difficult. Text editors have Undo, which comes in handy.
I'm not all that hot at grep; others may be better routines.
Hi Fenton,
Very good, I'm just learning Regular Expressions and Greps too.
You can shorten your Step 1 [color:"red"] ^([a-z|A-Z]+| )+ to [color:"blue"] ^([A-Za-z]+| )+ and I would add a 4th step as below.
Example, Step 1:
Find: ^([A-Za-z]+| )+
Replace: &t
Step 2:
d+ (w| )+,
Replace: &t
Step 3:
[^t]ddddd
Replace: &t&
[color:"blue"]And I would add a fourth step to put a tab between the State abbreviation and Zip code
Step 4
[0-9]+t
Finds the zip and and replaces it with a tab zip
Replace:
t&
You're right about the shorten; I didn't need the first pipe "|" (which means basically "or"). It's unnecessary inside the brackets. Actually you don't need any pipes. The following works also:
^([a-zA-Z]+ )+
You don't really need that 4th step. I made a mistake on the 3rd step.
Step 3:
[^t]ddddd
Replace: &t&
It should have been:
Replace: t&t
Whenever you can isolate an entire "field," which has no tabs yet, it saves a step to put a tab on each side.
Another method:
You could alternatively isolate the state. This would work in case the address didn't have a comma. But it would also match "DR", "ST", etc.. Street abbreviations can be pretty variable, often entered sloppily.
[A-Z][A-Z]
Hi Fenton,
I just realized that there was a mistake in your third step replace. Instead of
[color:"red"] &t& which gives you two zips, it should read [color:"blue"]
t&t , which does away with the need to use my fourth step. I suggest
instead a different fourth step to remove the excess spaces and comma.
These would be the new steps as amended. Be sure you use Grep.
Step 1
Replace: &t
Step 2
Find: d+ (w| )+,
Replace: &t
Step 3
Find: [^t]ddddd
Replace: [color:"blue"] t&t
Step 4
Find: [color:"blue"] ( t|,t |t )
Hi Fenton,
I was composing my response and posted it without refreshing my screen. I would normally just delete it since it says a lot of what you have just posted. However, I'm leaving it because of my "New" step 4.
