March 2, 200422 yr This is the code I have for a Text calc field GetRepetition( Quantity, 1) & "-" & GetRepetition(item,1) &"
March 2, 200422 yr Author I still do not know why it did not work, but I broke it up in to 2 fields, then made a third to combine the two fields and it worked I would still like to know why it did not work
March 2, 200422 yr Hi, Without going into your calculation too much, at first glance it seems you have 47 " You cannot have an odd number of " It appears to me that you have an extra " here: "GetRepetition ( Quantity, 3) Hope this helps Ed
March 2, 200422 yr Check your calculation.... "&If( (GetRepetition( item, 2) ) <===== looks like your calculation has an extra close-paren that may be messing up your result. I checked and it is on all the If statements up to 7. In each case, it looks like it will work if you just remove the bolded close-paren from each If statement. Good Luck Paul
March 3, 200422 yr Author Yup, it was that qoute that Eddy B suggested. Thanks! One odd thing that has happened. Usually it works fine. For e-mail, it looks just like the text field. Excep for one product that has "Z" as the first letter. This makes no sense to me, but there it is anyway. I just made a special argument, if that came up.
