Self Join Problem
I'm having a problem with creating a self-join. I must be doing something wrong, but I can't place my finger on it. When I create the attached self-join file, and then reference the relationship, it's showing blank records where the original records have been omitted... I'm sure it's really obvious, but I think I've been looking at it too closely...
Any help would be appreciated...
FileMaker Version: 6
Platform: Windows XP
test.zip
The idea of a self-join is to show information from other records that are related to the current record. I'm not sure what you are trying to do with your data; usually you have a form view with a portal to the related records.
Without getting into a lot of detail, this is a very simplified demonstration of the problem I'm encountering. I'm trying to create a view to a subset of data. The calculation will have a value set to only show some of the records depending on criteria from the user.
The fundamental question is why is this relationship returning blank records which don't seem to meet the join criteria, and how do I eliminate it?
Hope that makes sense...
See if the attached file helps.
When you change the Category, the relationship changes, causing the portal rows to change.
FileMaker Version: Dev 6
Platform: Mac OS X Panther
test2.fp5.zip
hi mtnman,
The answer is, that they are meeting a relationship criteria or nothing would appear. Unfortunately, they just aren't meeting the one you had in mind. This is probably do to the Key you are using is too broad of criteria (i.e. using a calculation ~Constant = 1, or something), or they aren't unique enough to pull just the information that you are looking for (such as using the Customer_I.D.). You might also want to check that the Fields in the portal are not coming from a different relationship than the one established for the Portal (i.e. the Current File, instead of the Related file).
HTH
That helped... However, I may just be trying to get to a solution, that I can't really get to this way. I was hoping a self-join would allow me to create a list type layout against the relationship directly.
So for example, if a user signs in with a "desktop" profile, they would get one list of records, while another user would sign in with a different profile and get a different set of records. I'm trying to avoid doing this based on security groups, but want to be able to simulate that sort of functionality...
Hi mtnman,
I didn't see the attachment you had posted, sorry.
However, you make the relationship based on the word Desktop, it may do what you are asking, see the attachment.
Platform: Mac OS 9
test.fp5.zip
but doing that creates a list of the same record over and over, rather than a list of unique records???
I don't grok Lee's response, but I think you could use scripting in conjunction with the self-join and the layout in your original post. Use a Go To Related Records script to pull up the set of records that user has access to. This will only work in situations where the user doesn't have access to perform their own finds.
Hi mtnman,
I didn't look at the second layout in your file. I think what you want is to view this information via a portal. See you file adjusted attached.
test.fp5.1.zip
Ender,
Thanks, unfortunately, that's exactly what I want to be able to do. I want the users to be able to perform finds against the list.
Thanks Lee,
That's sort of what I was trying to get at. Can you tell me how to do a find within the portal? If I can get that portion working, I think I'll have what I need...
Thanks for all the help...
Hi mtnman,
I have tried to answer your last post, not this one, and I keep getting interrupted, I have my grand kids here. Anyway, I hope this makes sense to you.
I have adjusted your file again in hopes it comes closer to what you want.
The file shows how to use a popup menu with a value list, to select a criteria, and then display the records in a portal.
to select a group of records and then and then using a Script Step, as suggested by Ender, go to a particular recorded within the selected group using "Go To Related Record" (GTRR) script step,
I made a a Popup Menu of the Global field and used your field "Category" as it's contents. Use it to select your criteria, and the portal will populated with the records meeting the criteria, you can then click on the GTRR button to go to a particular record.
HTH
Platform: Mac OS 9
test1.1.fp5.zip
I really appreciate the all the help. Let me see if I can explain what I'm really trying to get to.
I'd like to create a list based on a user logging in thru a custom login screen. Then once they've logged in, I'll gather a preference that was set for them. Then when they go into a list layout, they can run a standard type find against the list.
I'm pretty new to FM, but what I'm really trying to do is get the equivalent of a view in Oracle, but I really need the user to be able to run finds against any of the fields, so the portal doesn't seem to work the way I need...
I think I get it.
If you are using FM5.5 or FM6 you could look at the Record Level access priveleges. But I'd suggest scripting it. Just include the user's Category in the find script.
Enter Find Mode []
Set Field [ Category, Security_Link::Category ]
Pause/Resume []
Perform Find
In this case Security_Link is a relation into the current user's account prefs. There are a couple ways to do this, so if you want more info, you can look in the Security forum or the Sample Files forums.
ok, I see how to make it all work now...
Thanks again for the help...
Actually, another question just came up. How do I prevent the user from over-riding this by using Show all records?
For the passwords that your users use, set Available menu commands to "Editing Only" in the Access Privileges-->Passwords dialog.
By doing this, you will need to create buttons and scripts for navigation, record creation, and deletion operations.
