Stock calculations problem
Please have a look at my brain braking problem.
I'm building a system with the use of some new FM7 features which is using a single database for all stock changes.
The records contains a field for sold qty and one for bought qty.
Since every time something is bought it gets a new warehouse location, the idea is to create some relations and calculations which calculate if the stock in that record is still available.
Here's what it looks like now (simplified):
Table : stockmutations
Records:
Recnr. (calc) Get (RecordNumber)
Partsnr. (txt)
Qty bought (num)
Qty sold (num)
Location (txt)
stockchange (calc) qty bought -qty sold
I created a relation "Rel_Stock" from Table stockmutations to itself :
Partnr. = Partnr.
and a relation "Rel_Stock past" from Table stockmutations to itself :
Partnr. = Partnr.
Recnr. >= Recnr.
I added a field :
Available (calc) if (sum(Rel_Stock past::Qty bought)<(sum(Rel_Stock::Qty sold);"no";"yes")
This creates a no of the total qty bought in the previous records is smaller than what is sold overall.
I simplified above a bit since things as ordered parts, reservations etc are also included in what I made so far, but do not change my basic problem.
The value available is in my system also only set if it is a "bought"" record.
Now the problem.
It is possible that there is some stock at location A and location B so what I want to show in an other tables layout is a portal which shows only the records which have the value available "yes"
When I create a relation to table stockmutations with partnr = partnr and avalable = yes, nothing shows up in the portal.
I ran in to the limitation that a portal wont work when a relation is based in a relation.
Does anyone have an idea how to create something which does show only the available 'yes' records with the calculation like above.
I know it is possible with scripts which replaces the continues calculation but that could give a problem with multiuser situations and I just like to try it someway like this.
Your ideas are very welcome.
Marcel
If 'yes' is a global field in the main file containing the value "yes", then you can relate it to the available field. If 'yes' is a text or calculation field containing "yes", then your relationship can be accessed both ways.
Does this help?
