October 5, 200421 yr I have set up a simple script to add line items to an invoice. The script is as follows: Copy [select; invoices::order_number] New Record/Request Paste [select; invoices::order_number] Commit Records/Requests[] Refresh Window The record information is being pulled from a related table, but does not show up until you add info ie. quantity_billed and description_billed and then you flip to a previous record and back again. I cannot get this to refresh for anything. It would be ok if it just left the info from the previous record, but it goes blank as soon as you activate the script. HELP! TIA, .sly
October 5, 200421 yr Is this in your line items table? What is the record data you're wanting and how is it related to the invoice table? Have you tried using Set Field instead of Copy/Paste, first setting a global with the order_number, then setting the new record's key with the global?
October 6, 200421 yr Author Yes, it's in the line items table. The Orders and Line items tables have the order number in common. Line items shows only info for the item billed: Order Number = 12345 Quantity = 1 Description = Hours of Time Unit Price = $100 Total Price = $100 The Customer information such as customer name, address and phone number are being shown with fields related solely on the order number. I tried the set field command, which I like better, but that doesn't work either. .sly
October 6, 200421 yr Can you attach a stuffed sample copy of your file and indicate which layout is having the issue? I'm not certain if there is a fix for it, but something may jump out at me.
October 7, 200421 yr Author File sent to Queue, no problem seen on his XP station. Anyone else have any ideas? Appears now to be an OSX problem?
October 14, 200421 yr You can ignore my solution to set the segment field. Just use Refresh Window [Flush cached join results] after your Commit Records step.
