Problem with AddDBParam('-lop_end','or')
hi there !!
I have a problem with AddDBParam('-lop_end','or'). Can anybody give me some piece of code. I'm doing that in this way:
//version 1
for($i=0; $i<count($field_value); $i++){
$this->query->AddDBParam('-lop','or');
$this->query->AddDBParam($filed_name[$i],$field_value[$i]);
$data = $this->query->FMFind();
//version 2
but it's doesn't work :
thanx for any help !!
I'm not sure if this is your actual problem as it may just be a typo with your post, but you have a syntax error in your 'for' loop. You have a variable $filed_name that I'm assuming should be $field_name. You don't show in your code where this variable has been set or what its value is.
Cheers,
Kevin Futter
i know that name of variable is different, but it's not a problem...I created class which i'm using to add/update/delete records from different layouts. I will show you whole function:
//code
function getInfo($field_name, $field_value, $sortfield='', $sort_type='', $operator=''){
unset($this->vars);
$this->vars = array();
if(!empty($sortfield)){
$this->query->AddSortParam($sortfield,$sort_type);
for($z=0; $z<count($field_name); $z++){
$this->query->AddDBParam($field_name[$z],$field_value[$z]);
if($data['errorCode']!=0) {
return 0;
$j=0;
foreach ($data['data'] as $key => $instanceData){ // numbers of rows in database
for($i=0; $i<count($this->fieldNames); $i++){ // numbers of fields
$this->vars[$this->fieldNames[$i]][$j] = $instanceData[$this->fieldNames[$i]][0];
$j++;
return 1;
//end
basically $field_name and $field_value are arrays
thanks for any help !!
