Jump to content
Using PatternCount on a portal
This topic is 7643 days old. Please don't post here. Open a new topic instead.
Recommended Posts
Posted
Nope, you have to define a new list utilizing the relation:
1) define valuelist
2) use values from field (press specify)
3) choose table and field
4) CHOOSE "Include only related values" including the from....
It would probably take some time to grasp if you havn't done it before ...The easiest way to check is to make a unstored calc' with ValuelistItem( before you let it be part of the inner mechanics of the solution.
Posted
Joseph,
Take a look at the last sampler I submitted as it should answer the case with very small adjustments. I preferred Soren's for the initial need of a Yes/No flag, but if in fact you need to do some dynamic comparisons on the index, having the Value List deployed is the solution.
The calc used to determine wether there's one or many brokers is actually evaluationg the number of pillcrows. Just change it so that you get the number instead of the "Only one/More han one" result.
Posted
You guys are so above me in FM is Funny... I like learning this stuff but I does get a little confusing when you have so many relationships already...
I will study the sample that you gave me... Thank you..
Joseph
Posted
Ok I give... I am just not that good at this yet.. If it is no trouble can you show me an example... All I want to do is count (Number for the answer) how many times in a portal column a new word shows up...
ex:
Bob
Bob
Jack
would be 2
ex:
Bob
Bob
Bob
would be 1
Thank you
Posted
Ok, fter pulling my hair out... I got it to work with my data base... I really thank you for showing me this...
If you have the time can you answer these for me:
1. What are the Parigraph marks; and what do they mean?
2. Why does it say 1 even if ther is no entry in a cell... can it say 0 or stay blank if there is no entry
Thank you
Joseph
Posted
Are you ready for the next trick?? Draw a new portal around the calcfield showing the same relation as the portal. But here is it just one row and the lines the portal consists of is changed to none width. This is known as the visibility trick. The field in the portal isn't from the related table but is the calc with ValueListItem( ...
http://www.filemakerpros.com/Visible.sit
http://www.filemakerpros.com/Visible.zip
Why do I make such a silly thing? Because debugging as well as recalculations are faster than building the calculation that otherwise would dependant on the number fo rows in the portal.
If we should have done it that way would the calc have been:
Case(Count (RecordsinPortalFile PORTAL::LogInID;PatternCount(ValueListItems(Get(FileName);"RelatedBrokers")& "
Posted
I know why you are similing in your picture... It's b/c you are really good a FM. Ok, I think I am ready for your next trick, but I have to ask something first before I do a lot of thinking to follow what you are saying...
I wanted to use the calc field with an report... meaning when you print a report it will show how many there are for that field (Difference only). So if I make a new portal and then make it invisable does that mean it will not show up on the report as 1 when there are really zero?
Joseph
Posted
No you're correct here, the Case( is what's required here! And it might even have to be put inside an Evaluate( to provide correct breakings??
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Create New...
