My related field is not updated, Allow entry issue
I have a related field on my layout that is not updated when the "mother record" is updated.
The specific field has allow entry not checked.
If i make a copy of this field but with allow entry checked the updated works perfect.
I have tried numerous solutions
redraw screen
goto related record
empty chache
Please help me out on this one
Thanks Jitse
In addition:
When i manual zoom the window and unzoom again the related field displays the correct value.
If i create a calculated field that copies the value of the related field the calculated field is updated
correct.
Oh yes : FM 5.5 developer OS X 10.2.8
Weird
Jitse
Try Enter Find Mode [ ] Enter Browse Mode.
Thanks, but that did not work.
Offcourse, i can make calculation fields, but any other suggestions are more then welcome !!
jitse
Can you post a sample?
Please have a look at the attached file (parent.fp5 and child.fp5)
Thanks Jitse
Use Enter Preview Mode [ ] Enter Browse Mode [ ] in each script.
That did the trick but ........
is this a bug ......
is it stil there in FMp7 ??
Jitse
In 7 you would use Refresh Window [Flush cached join results].
You have a calculated field based on a global from another file and a relationship using this calculated field to display another field from that file. You wouldn't have this issue if you just set a global in Parent and used it for your index relationship.
