FileMaker 2026 Released
Required field on web form using CDML, HELP
HELP,,, I have a form with a field "ori" and listvalue coming from the db as session (example below). I want to make the field required to select a value by user. If not selected then a pop window will remind or not continue if submitted. I tried javascript, and it works with text fields but with example below, not at all. Help needed. Thanks in advance.
--------JAVA SCRIPT
<script language="javascript">function validate(){
if (document.testform.ori.value==""){
alert("No Orientation Session. Please Enter a Session!")
return false
return true
}</script>
----------FORMAT
<FORM ACTION="FMPro" METHOD="post" name=testform onsubmit="return validate()">
<INPUT TYPE=hidden NAME=-DB VALUE='enrdatab'>
<INPUT TYPE=hidden NAME=-Lay VALUE='web'>
<INPUT TYPE=hidden NAME="-Format" VALUE="record_detail_replyo.htm">
----------field on form
<select name ="ori">
[FMP-option: ori, list=session]
</select>
Try this:
--------JAVA SCRIPT
if (document.testform.ori.selectedIndex < 0){
return false
return true
}</script>
Garry
