Finding Min, Max, and next before max
Hi all
I can find the min and max date a welder has welded, but i also need to find the date before the max date.
example:
Terry welds on 1/3/05
3/6/05
4/6/05
5/6/05
7/24/05
8/23/05
I can find the first date using "min" and the last date using "max" but i can not figure out how to find the date before "max" which would be "7/24/05".
Any ideas and suggest would be greatly appreciated
Thnaks in advance
Lionel
Show All Records
Set Error Capture [ On ]
Enter Find Mode [  ]
Show Custom Dialog [ Title: "Oi Dude"; Message: "Enter name of the welder"; Buttons: "OK"; Input #1: Untitled::WelderName ] Perform Find [  ]
Sort Records [ Specified Sort Order: Untitled::Days; ascending ] [ Restore; No dialog ]
Set Error Capture [ Off ]
If [ Get ( FoundCount ) > 2 ]
     Go to Record/Request/Page [ First ]
     Omit Multiple Records [ Get ( FoundCount ) - 2 ] [ No dialog ]
     Go to Record/Request/Page [ Next ]
     Omit Record
Else
     Show Custom Dialog [ Title: "Error!"; Message: "Nothing found"; Buttons: "OK" ]
End If
Dang ...you're on 6.0 then do you have to...
Show All Records
Enter Find Mode [  ]
Perform Find [  ]
    Go to Record/Request/Page [ Last ]
    Omit Record
    Loop
            Go to Record/Request/Page [ Previous; Exit after last ]
            Omit Record
    End Loop
Else
End If
Define a value list "Dates", using values from the date field, include only related values, starting from your welders table.
Then, in the welders table define a calculation field (unstored, result is date) =
Let ( [
list = ValueListItems ( Get (FileName) ; "Dates" ) ;
last = ValueCount ( list )
GetAsDate ( MiddleValues ( list ; last - 1 ; 1 ) )
Oh, version 6, bummer - I don't even know which functions are available in 6.
Try:
Middle(
ValueListItems(Status(CurrentFileName). "Dates") ,
Position(
ValueListItems(Status(CurrentFileName), "Dates") , "¶" , 1 , PatternCount( ValueListItems(Status(CurrentFileName), "Dates") , "¶") - 1 ) + 1 ,
Position(
ValueListItems(Status(CurrentFileName), "Dates") , "¶", 1, PatternCount( ValueListItems(Status(CurrentFileName), "Dates") , "¶") )
- Position(
ValueListItems(Status(CurrentFileName), "Dates") , "¶" , 1 , PatternCount( ValueListItems(Status(CurrentFileName), "Dates") , "¶") - 1 ) - 1
Dear me Comment....Hows about
RightWords(
Substitute(ValueListItems(Status(CurrentFileName), "Dates");
RightWords(ValueListItems(Status(CurrentFileName), "Dates");
 3); ""); 3)
If we're to be in almost excell mode B)
SOren Dyhr and comment
thanks a bunch both of you are life savers
Lionel
I have stayed away from counting words, because the result depends on the date format. In pre-7 versions:
8/25/2005 = 3 words;
25-8-2005 = 3 words;
but
25.8.2005 = 1 word.
I am sorely tempted to accuse you of being an Americano-centrist and ignoring the rest of the world!!!
Good grief, couldn't I pursuade you to call me "Daft as a brush" instead ...the other is unbearable B) : : :B:B - But the script then, it had some bite didn't it???
