Problem with Reporting
Hi every one,
I have Find [] script that finds the modified records per Current Date.
Also I am produsing a report , new layout, with sub summary and summary based on the user and manager. I am counting the records per user and per manager. I do not have a problem here. The problem is that I need only the Syb Summary per User and SubSummary per manager . I do not need to show the actual record.
I do not select the fields for the report layout.
When i do that the data from records are not showing but still I have "empty rows" (records) ...
Can you help me? How do i correct that?
I need to "Now show the records" , only the summary!
thanks a million
Allow FM to create the report will all fields and the body.
Then delete the body. :wink2:
If you don't want the detail to list, delete the body AFTER the report has been created.
L
LaRetta,
as always you are great.
How do I do that?
thanks,
Go into Layout mode on that layout.
See the grey tab called body? Click it once just to select the body. Then hit 'Delete'
LaRetta,
THANK YOU!
It is so simple, I tried working with
OMIT RECORDS, but as you already know it is not working...
Do you know how to restrict the user form using BROWSE, and FIND mode only for one layout?
Hoping that it not too much!!!
Thank you,
