Help with Menus needed
Hi all, I am a new member to the forums and this is my first post so here goes.
I have been using filemaker 6 for a month or two in an office enviroment on a Mac platform and now have the need for custom menu's. Idealy I would like to remove/disable the "duplicate record" command in the Records menu. I see in the "access privilages" I can disable "Delete records", "Create records" and so on but no "Duplicate record"! I also tried changing the "Available menu commands" section to "editing only" but this does not have the desired affect. Could you please advise on the best solution to remove this command when using a certain password to access the file.
Thanking you in advance ;)
Jeff
To have custom menus, you will need to upgrade to FM8 or use a plugin such as Dacon Menu Control.
