Simple calculation problem
I have a FMP6 data base with a date field.
I want to define a new field (called Term) where the data is a calculation based on the date field:
ie if the data is within a range of dates eg between 30/1/06 and 30/4/06 (Aust format) then a number eg 1 goes in the Term field.
I can't work out how to write the If statement...
help please
Strictly speaking you don;t need an If statement... this expression will resolve to either 1 or 0. You only need an If to replace the 0 with null if that's what you prefer.
Term >= Date( 1, 30, 2006 ) and Term <= Date( 4, 30, 2006 )
Hi Vaughan
Actually, I wanted to define the Term field for school terms ie Term 1, Term 2, Term 3 Term 4...I'm not sure if your response will work!
So far the calculation is
(Term=)
_______
If(ASdate>=30/01/2006
and
ASdate<=30/04/2006,
1,
_______
My problem is in defining the range
Once fixed I will replace ""
with another calculation for dates for Term 2
etc
I know its simple but I can't work it out!!
Are there qoing to be 4 equal terms, as in a fiscal quater?
No
they're school terms
the start and finish dates change
To clarify
I have an FMP6 related file with fields relating to student names, and detention dates (ASdate).
I have some layouts that summarise the data according to the school term.
I manually input the date of detention but I wanted to set up a calculation that would automatically insert the appropriate school term in another field based on a range of dates already inputted in the detention date field.
The calculation field is organised as previous posts but when I try to calculate within a range of dates I can't get a result.
Is this more complicated than I think it is?
Cheers
You are going to have to describe the start and end of your terms
I have used four fields, plus your Date Field and the calculation.
[color:blue]ASdate
Term1_Start
Term1_End
Term2_Start
Term2_End
All Date fields
TermCalc (Calculation, Number) =
Case( ASdate ≥ Term1_Start and ASdate ≤ Term1_End, 1,
Case( ASdate ≥ Term2_Start and ASdate ≤ Term2_End, 2 ))
You will need to modify this for additional Terms.
HTH
Yippee (haven't used that word in a long time!)
Thanks Lee
had to make them Global date fields to work how I wanted them to...still yippee
Stephen
