July 17, 200619 yr Hi, Why I don't get any sound alert when I use 'beep' script step. My sound card & internal speaker are both working but I don't hear any beep from FM. Any help would be appreciated. Regards, Garry
July 24, 200619 yr Author hmmm... not a single reply or comment? It seems that beep function is a totally vanished feature... Garry
July 24, 200619 yr It works for me. Although its more of the thunk sound than a beep. My guess is the the problem is more likely with your OS than FM.
August 14, 200619 yr My guess is that the system you're using has been set not to play any sounds. Just change your settings in the control panel (sounds and audio devices) on XP (no clue on a mac).
