Record doesn´t exist problem
hi
when im searching for emails in my database the ones that doesn´t exist results in a notification "record doesnt exist". is there anyway to add them to my database? if my search results in a record that doesnt exist cant i simply just have it added as a new record?
Yes, you can do that. But it should be obvious that you're going to have to write a script for that purpose. FileMaker is a great application, but it can't read your mind.
If you're asking how to know if a record wasn't found within a script...
Put this at the begiining of your script:
Set Error Capture[On]
And this right after you perform your find:
If[ Get(LastError) <> 0]
What to do if your script doesn't find any records here.
End If
