Need Help with portals
Im new to portals, I am creating a simple database where a telemarketing company needs to lookup a client and see past donations and also enter new donations i would like to have them all show up in portals but im having trouble doing this :o any input would be great
You need a Client table and a donations table. There should be a relationship from ClientID (autogenerated) to a field in the donations table that will store they ClientID number (foreign key). You can check the Allow creation of records for the Donations table in the relationship to allow new records to be created via the relationship.
On the layout for Clients, you can create a new portal. Then reference that relationship you created before. Then put the fields that you want on the portal's first row.
im still struggling, if i send the file could you fix it for me?? ill send you some $$ with paypal :o
You can send me the file. I will try and help you. No paypal needed my friend.
Ill have to finish all the designing, it wouldnt feel right not sending $$ there are a bunch of functions that i cant do that i would like and its a big help to me. what is your email address ill send the file this weekend
My email address can be accessed via my profile but just in case its vodkacream_at_yahoo_dot_com.
:o-)
emailed ya
