January 19, 200719 yr I am wanting to make a reusable script for a "Quick Find". Basically I want a script that I can pass via a script parameter the value I want to search for and the object names for say 3 fields I want the find to search for. Obviously this would not be necessary if I used the Set Field step, but I want this to be a script I can simply copy into any file and based on the script parameter passed would work on any table without any modification. For example I would pass "Name|object1|object2|object3" to the script. The script would then parse out the four values into variables $Value, $o1, $o2, and $o3 and search for the value in any of the three fields. Where I am at now is that I switch to find mode, and use the Go To Object script to go to $o1. This works fine, but how do I "paste or otherwise" the $Value into this field to perform the find. I can not paste because the $Value is not on the clipboard. I can not use the Set Field because I would have to specify the field and it would defeat the purpose of portability. Nor can I use relationships for the same reason. If I use the Insert Text step it simply pastes the text "$Value" into the field. Any ideas, or is there just a better approach that I am missing?? Thanks for any and all help!
January 19, 200719 yr Gosh, I had a similar problem a while back where I had to paste 20 data into 20 fields for 2,000 records and i didn't want to create 20 set field script steps. By the way, you have to use Insert calculated result, not set field for the paste to work correctly in that case. If I remember correctly, I used the evaulate function and simply used a string of text to define the field name. But that will only work when testing the field name. There is no way that I know of to dynamically create field names with the set field step. Did I help you at all?
January 19, 200719 yr You CAN use Set Field[] without specifying the field - it will set the currently selected field. So if you managed to make the correct field active by using Go To Object[], you should be fine. Of course, this method requires you to navigate to the correct layout, and the field/s in question to be on that layout.
January 19, 200719 yr Author You are the MAN comment! I guess it doesn't pay to work late into the night sometimes.
