Container fields for LED indicators.
Hi.
I aplogise for boring some of you with a simple question, but between the three FmPro books I have here, I cannot work out how to do this.
I have several small images (16 x 16 pixels) that are essentially LED indicators. I want to be able to use these in rows of data to indicate various conditions of data - eg overdue dates, inactive job etc etc. There are, lets say, 7 records (images). 1 off/inactive LED, and 6 brightly colored ones.
I can create a table with a container field in which I can insert those images into, but cannot quite get my head around how to use them again.
As each record may have 4 indicators alongside the text field to display various conditions, Im not sure how to set conditions on the container fields in the layout to display the indicator as required.
I dont expect a full-on solution, but some tips as to how I can choose various graphics under various conditions. A pointer to a sample database or web page would be great.
Thanks peoples.
Greg
Put the images in a global repeating field (in any table). Use a calculation field, with Container as the result, to select the repetition number, e.g.
GetRepetition ( gImages ; Case ( ; 2 ; ; 5 ; 1 ) )
You could even use one repeating calculation field to select all 4 indicators.
BTW, using colored text bullets instead of images would be both simpler and faster.
Hi.
Thanks for that, I will givve it a shot.
Cheers,
Greg
