October 3, 200718 yr Is there a script step equivalent to the Control-Home key combination on the PC? When the user tabs to a text field containing a large block of text, FileMaker places the cursor at the end of the block and the first lines are out of view at the top. Control-Home on the keyboard shifts the displayed text back to the top. I need to provide a on-screen button to do the same thing for easy mouse-based viewing. I've tried Set Selection [] with coordinates of 1 and 0. That moves the cursor to the first character, but doesn't shift the displayed portion upward, so the text cursor disappears. I'm drawing a blank on how to accomplish this and any suggestions will be appreciated. Thanks.
October 3, 200718 yr If you do a COMMIT RECORDS before your SET SELECTION that should do what you are looking for. Assuming that commiting the record then won't mess-you-up in other ways.
October 3, 200718 yr Author Thanks for the response. I forgot to mention that the field is in a portal and the user may have tabbed down several rows. Commit Records/Requests causes the field to lose focus, the same as a SetField[]. Any other ideas?
October 3, 200718 yr I've noticed this bug back in version 7, and it's still around - even worse. You could try the following hack, but for some reason it won't work in version 9. Set Selection [ Table::Textfield; Start Position: 1; End Position: 0 ] Insert Text [ “¶” ] Set Selection [ Table::Textfield; Start Position: 1; End Position: 1 ] Clear [ ]
October 4, 200718 yr Author comment, thanks. Your post gave me an idea to try something even simpler: Set Selection [start Position: 1] Insert [] It seems to work -- at least in the cases I've test so far. It operates on whatever field the cursor is in at the time.
October 4, 200718 yr Ah, of course. Didn't occur to me I could just leave the text box empty - thanks for that. And I finally found a way that will work in version 9 too: Set Selection [start Position: 1] Insert [] Undo You might want to add that to future-proof your solution.
