Problem with Get(scriptresult)?
I have an application where the contacts are stored in one file and tasks are stored in another.
Within the "tasks" file, on creating a new task I wish to enable the user to search for the org id eg as follows:
script in tasks:
perform script "quick lookup" from file "contacts"
Set field tasks::org_id; get(scriptresult)
Scripts in contacts:
quick lookup
(abbreviated):
new window
go to layout "quick lookup"
loop
Pause/resume script(indefinitely)
end loop
select company triggered by clicking on an item in the found list on quick look up layout
set variable $chosenid; orgid
close window (current window)
exit script (result;$chosenid)
MY problem currently seem manifold but the main one is that at the point i return to the main scirpt the get(scriptresult) value is blank
Secondly there seems to be no consistency in whether i end up in the tasks file or the contacts file? (both files have quite long startup scripts)
Any pointers most gratefully received.
thanks
simon
I am only guessing here, but it looks like 'select company' is NOT a subscript of your 'script in tasks' - or of any other script.
i am not sure about "sub scripts"
- the "select company" script is not called by a "parent script" it operates independently in response to a user clicking on a field on the "quick lookup" layout and is supposed to deliver the org id , and of course halt the loop... (which it doesnt seem to do either)
does this help or would you like/need more info
many thanks
s
That seems to be the problem - a script result is passed by a subscript to the calling parent script. Your script passes its result to thin air.
I think (haven't tested it) something like this should work:
QUICK LOOKUP
New Window
Go to Layout [ "Quick Lookup" ]
Set Variable [ $$chosenID ; "" ]
Loop
Exit Loop If [ not IsEmpty ( $$chosenID ]
Pause/Resume Script [indefinitely]
End Loop
Exit Script [ Result ; $$chosenID ]
SELECT COMPANY (set the button to Resume paused scripts)
Set Variable [ $$chosenID ; OrgID ]
Close Window [ Current Window ]
Many thanks - will try this tomorrow am
cheers
simon
Comment,
Many thanks for the suggested scripts - in the event I thought I would try something your ideas suggested to me:
On the select company script i changed the button setting to "exit" current script - and everything seems to work
the only thing that seems to mess up is if the orgs file is not open before the quick lookup script runs.
I have put a line in as follows:
If ValueCount(WindowNames("contacts"))<1
is this the best way to check for a file being open?
Once again thanks for all your help
Simon
You could also try the DatabaseNames function.
oh right
changed it for:
not IsEmpty (FilterValues (DatabaseNames;"contacts"))
