FM6 Solution Linking Problems
Using FileMaker pro 6
I have a solution that has 20 plus files in a folder however the main startup file is outside the folder... I now want to get it inside the folder ( with the other files).
Q: How best can I rework this solution and place the start-up file inside the main folder - and easily re-link the many relationships?
As an example: I tried fooling around with this - closed the files - then moved the start-up file into the main folder - then attempted to re-link manually in the relationships window.
I reset the links on one file - tested it - and it worked - then quit the solution. When I opened it again - the links did NOT hold - and went back to the original ( broken) State.
Q: Why did the new links not stick...? How can I get them to stay?
BTW: I do have fm developer 5.5 - but I believe it needs all the files in the Same folder prior to performing functions such as renaming etc. - right? If it can help with this issue - please let the know...
Hi folks,
Still curious about this especially...
Hi folks,
